Migrate DFS Volume to another volume on same server
2021-09-27T10:51:51.473+00:00
We have two DFS servers each has an StorSimple volume attached.
We want to move away from StorSimple, so we are going to attach an additional volume on each server.
How do I migrate over to this new volume?
Thank you
StorSimple
StorSimple
A Microsoft hybrid cloud storage solution that combines on premise hardware storage and cloud storage.
Windows for business | Windows Server | Storage high availability | Other
Leon Laude 86,221 Reputation points
2021-09-27T10:55:56.037+00:00
Hi @Anonymous ,
DFS only creates the links, so to migrate the actual data you have a few options, personally I would recommend robocopy.
Use robocopy or any other equivalent tool to copy your data from your StorSimple volumes to your new volumes, if the new volumes are attached to your existing DFS servers and the drive letters are the same then you won't need to do anything within DFS itself.
The drive letters may be different during the copying, but once you have all data copied from the StorSimple, set those volumes offline, and assign the same drive letter to your new volumes and you should have everything working again.
If the reply was helpful please don't forget to upvote and/or accept as answer, thank you!
Best regards,
Leon
1 additional answer
  1. Limitless Technology 40,116 Reputation points
    2021-09-27T19:57:30.047+00:00
    Hello @Shofi-89
    This is the official documentation from microsoft regarding StorSimple migration:
    https://learn.microsoft.com/en-us/azure/storsimple/storsimple-8000-migration-from-8000-options
    Hope this helps with your query,
    --If the reply is helpful, please Upvote and Accept as answer--
