Double-click a word and drag to highlight does not work on OneNote!
Kirsten Frost 0 Reputation points
2025-12-12T07:55:10.7066667+00:00
So the way this is supposed to work is that you double-click a word, then while still holding, you drag a section of text and then you're highlighting that section. If you try it literally on any program on your computer, it will work. Except on OneNote! WHY!!! I do this so much that it messes with my work-flow in unimaginable ways. I cannot stand it.
I am using Macbook Air, M4. It's the Microsoft OneNote for Mac, version 16.103.4. It is an educational subscription, so I don't know if that changes it.
I can do this functionality on outlook, on powerpoint, on word, microsoft edge, etc. I dont know why I can't do it here...
Microsoft 365 and Office | OneNote | For education | MacOS
  1. Bob Jones AKA CyberTaz MVP 435.8K Reputation points
    2025-12-12T18:14:59.05+00:00
    I'm not sure why it takes extensive paragraphs to explain that OneNote simply does not have the same array of editing features found in other text based programs. In particular, it lacks most of the techniques for extending a selection.
    The most effective alternative is to place the insertion point at one end of the passage then hold the Shift key while clicking at the opposite end — no dragging involved. You may even find that to be a preferable technique.
    2025-12-12T10:01:01.74+00:00
    Hi Kirsten Frost
    Thank you for reaching out to Microsoft Q&A Forum and sharing your experience.
    I understand how disruptive it can be when familiar text‑selection gestures don’t behave as expected.
    I tested this behavior on OneNote for Mac version 16.104, and the results appear to be the same across supported macOS versions. At this time, OneNote for Mac may not fully support the “double‑click + drag to extend selection” gesture that works reliably in many other macOS applications. OneNote uses a different text‑editing engine from the other Office apps, so some macOS text‑handling behaviors are not implemented consistently across the suite.
    In the meantime, here are a few workarounds that currently function reliably in OneNote for Mac based on my testing:
    • Triple‑click to select an entire paragraph, then use Shift + click or Shift + arrow keys to fine‑tune the selection.
    • Double‑click a word to highlight it, then hold Shift and use the left/right arrow keys to extend the selection.
    If this gesture is important to your daily workflow, I recommend sharing your feedback directly with the OneNote team via the Microsoft Feedback Portal. User feedback is a key factor in prioritizing improvements across platforms.
    While this Q&A forum is a helpful place to share findings and receive guidance, submitting feedback directly to Microsoft is the most effective way to influence product development. Your input is truly appreciated and helps shape future improvements.
    Thank you for your patience and for continuing to advocate for better usability and accessibility in OneNote for Mac.
  3. AI answer
    2025-12-12T07:55:17.4033333+00:00
    The issue you're experiencing with highlighting text in OneNote for Mac could be related to the specific functionality and limitations of the OneNote application compared to other Microsoft Office applications. While double-clicking to select a word and dragging to highlight text works in programs like Word, Outlook, and PowerPoint, OneNote may have different mouse interaction behaviors.
    Unfortunately, the context provided does not specify the exact reasons for this limitation in OneNote for Mac. It's possible that the application does not fully support the same text selection methods as other Microsoft Office applications. If this functionality is critical to your workflow, consider providing feedback to Microsoft or checking for updates to see if this feature is improved in future releases.
    For now, you might need to use alternative methods for selecting text, such as clicking and dragging to highlight or using keyboard shortcuts for text selection.
