i can print from every thing but control p
David Durbin 0 Reputation points
2025-12-04T22:25:54.3733333+00:00
i just install a ne printer to fix the fact that i can't use control p everything works but that
Microsoft Teams | Microsoft Teams Free | Teams Insider Program
    2025-12-04T22:26:03.53+00:00
    It sounds like you are experiencing an issue with the print functionality when using the Control + P shortcut, even after installing a new printer. Here are some troubleshooting steps you can try:
    1. Check Default Printer: Ensure that the new printer is set as the default printer. You can do this by going to Settings > Devices > Printers & scanners and selecting your new printer.
    2. Test Printing: Try printing a test page from the printer settings to confirm that the printer is functioning correctly.
    3. Application Specific Issue: If printing works from other applications but not from the one you are using with Control + P, the issue might be related to that specific application. Try updating or reinstalling the application.
    4. Check for Updates: Make sure your operating system and printer drivers are up to date. You can check for the latest printer drivers from Microsoft printing support.
    5. Print Spooler Service: Ensure that the Print Spooler service is running. You can check this by typing services.msc in the Run dialog and looking for the Print Spooler service.
    6. Reinstall Printer: If the issue persists, consider removing the printer and reinstalling it to ensure all settings are correctly configured.
    If you continue to have issues, please provide more details about the specific application you are trying to print from, as that might help in diagnosing the problem further.
  2. Kimberly Olaño 23,610 Reputation points
    2025-12-04T23:06:54+00:00
    Thanks for sharing the details, David! Try to check if Ctrl key is failing (Windows trick).
    Use the built-in keyboard viewer to confirm whether Windows sees the Ctrl key being pressed.
    Steps
    Press Windows key + R
    Type: osk
    Press Enter (opens the On-Screen Keyboard)
    Press Ctrl on your real keyboard
    Does the Ctrl key highlight on the on-screen keyboard?
    • Yes → your Ctrl key works; the problem is software-related.
    • No → your physical Ctrl key is failing. Try another keyboard.
    See if this helps. If you need further assistance just let me know.
    Best regards,
    Kimberly
