Participating in early access and feedback programs for new Teams Free features
The error message indicating that the license key cannot be located for Word, PowerPoint, and Excel usually occurs due to issues with the software protection platform or if the applications are running in compatibility mode for a different operating system. Here are some steps you can take to resolve the issue:
- Check the Software Protection Platform Registry Entry: Ensure that the registry entry for the Software Protection Platform exists. If it is missing, you may need to export it from another device where Office is functioning correctly and merge it into the problematic device's registry.
- Stop Running the App in Compatibility Mode: Right-click on the Office application (Word, PowerPoint, or Excel), select Properties, and ensure that the compatibility mode is not enabled. If it is, disable it and apply the changes.
- Repair the Office Installation: You can also try repairing the Office installation through the Control Panel to fix any corrupted files that might be causing the issue.
- Restart Your Device: After making changes, restart your device and check if the issue persists.
If these steps do not resolve the problem, you may need to consider reinstalling Office or contacting Microsoft support for further assistance.
