guidance and help to create a setup
Niharika P 60 Reputation points
2025-11-13T12:36:14.7466667+00:00
We need help for set up and also a few related documents.
We actually have a hybrid work culture, and we want to setup an Intune or conditional access where if the employee's login to Microsoft admin portal using the personal laptop the access needs to be blocked, and we need to be notified about that and the access needs to be there only for the employees using office laptop
Microsoft Security | Intune | Compliance
AI answer
2025-11-13T12:36:34.62+00:00
To set up a Conditional Access policy that blocks access to the Microsoft admin portal from personal laptops while allowing access only from office laptops, you can follow these steps:
  1. Sign in to the Microsoft Entra admin center as at least a Conditional Access Administrator.
  2. Navigate to Entra ID > Conditional Access > Policies.
  3. Click on New policy.
  4. Name your policy meaningfully, such as "Block Personal Devices Access."
  5. Under Assignments, select Users or workload identities:
    • Under Include, select the users or groups you want to apply this policy to (e.g., all employees).
  6. Under Conditions, you can specify the device platform:
    • Set conditions to check if the device is compliant or hybrid joined. You will need to ensure that only office laptops are compliant with your Intune policies.
  7. Under Access controls > Grant:
    • Select Block access for non-compliant devices.
  8. Enable the policy and confirm your settings.
  9. After testing the policy in Report-only mode, switch it to On to enforce it.
Additionally, to receive notifications when access is blocked, you can set up alerts in the Microsoft Entra admin center or use Azure Monitor to track sign-in attempts and failures.
Make sure you have compliance policies set up in Intune that define what constitutes a compliant device, such as requiring device encryption or a specific operating system version.
