Power point audio presentation problem
mahesh sanghvi 40 Reputation points
2025-11-10T14:12:33.3966667+00:00
I have power point slides with inserted music
i wanted to delete from all slides background music but some how it does not delete I tried by going through animation and all other suggested area in power point to delete from all slides
some one knows how to remove the back ground music inserted in the side be removed will be helpful to give me instructions
regards
Moved from: Community Center | Discuss the Q&A site | Site suggestion
Microsoft 365 and Office | PowerPoint | Other | Other
JC 8,225 Reputation points Independent Advisor
2025-11-10T19:43:47.5966667+00:00
Follow this guide on how to edit audio clips for powerpoint presentations.
Add or delete audio in your PowerPoint presentation - Microsoft Support
There is a video in the page which can act as a visual guide, it shows you how to delete audio clips at the 1:55 timestamp.
Hope this helps,
JC
AI answer
2025-11-10T14:13:18.37+00:00
To remove background music from all slides in a PowerPoint presentation, follow these steps:
  1. Open your presentation in PowerPoint.
  2. Go to the Slide Master view: Click on the "View" tab and select "Slide Master". This will allow you to make changes that affect all slides.
  3. Select the Master Slide (the top slide in the Slide Master view). This slide controls the overall layout and design for all slides in your presentation.
  4. Look for audio icons: Check if there are any audio icons on the Master Slide or any of the layout slides beneath it. If you find an audio icon, select it.
  5. Delete the audio: Press the "Delete" key on your keyboard to remove the audio from the Master Slide.
  6. Exit Slide Master view: Click on the "Slide Master" tab and select "Close Master View" to return to your normal slide view.
  7. Check individual slides: If the music still plays, check each slide individually to ensure that there are no audio clips added to them directly.
By following these steps, you should be able to remove the background music from all slides in your presentation. If you continue to experience issues, it may be helpful to check for any additional audio settings or animations that might be affecting playback.
