Other issues or features related to Microsoft Edge on Windows 11
This browser is no longer supported.
Upgrade to Microsoft Edge to take advantage of the latest features, security updates, and technical support.
The updates of Edge browser since 3/11/2025 have messed the browser theme up.
Now, whatever theme I choose, the browser reverts back to the "light" theme. If i go to the settings, the settings show that "dark" is chosen!!! but what i see is "light" theme everywhere!
what is going on?!?
AI answer
It seems like you are experiencing an issue where the Microsoft Edge browser theme is not applying correctly, despite the settings indicating that the dark theme is selected. This could be due to a bug or glitch in the browser following recent updates. Here are a few steps you can try to resolve the issue:
If these steps do not resolve the issue, it may be worth checking the Microsoft Edge support forums or contacting Microsoft support for further assistance.
Windows 11 settings > Apps > installed apps > Microsoft edge > three dots menu > Modify > Repair
This solved the problem at the moment without resetting the browser. I maintained all my favourites, extensions and settings.
The problem persists. and nothing worked.
reinstalling Edge, didnt work
resetting Edge, didnt work,
nothing is working. it seems to be a fundamental flaw
Hi @t m,
I apologize for the inconvenience you’re experiencing with configuring dark mode in Edge. I understand it can be uncomfortable to browse in light mode when that’s not your preference. Since the standard settings indicate “Dark” but aren’t applying correctly, we’ll need to refresh the browser’s theme engine using the internal flags menu.
Please follow these steps to force a reset of the theme configuration:
Step 1: Open the flags menu
Step 2: Locate the dark mode setting
Step 3: Toggle the setting to force a refresh
Step 4: Revert to normal
Step 5: Verify Your Theme
Go to Settings > Appearance and try selecting Dark again.
I'm looking forward to your reply.
If i change Windows theme settings for apps to "Dark", the Edge light theme issue disappears, but then all apps in the system becomes dark which i don't want.
Moreover, Edge theme settings is "Dark" and NOT "system" thus system theme should NOT affect Edge theme at all. May I mention that this Edge theme issue is a recent bug in Edge after it was updated 1 month ago.
In short, Edge theme indeed seems to be following the system theme for apps DESPITE settings Edge theme to "Dark" and NOT "system"
