Edge Mobile does not sync tabs
Tareq Hijazi 0 Reputation points
2025-10-05T06:09:41.66+00:00
Edge Mobile (Android, Samsung Galaxy Fold 7), does not show Tabs from other devices although Sync is on and sync open tabs is set to ON, I have other Windows PCs and from Edge Desktop I can see Tabs from other devices, including Tabs open on my Android mobile.
Microsoft Edge | Tabs, address bar, and search | Android
  1. paulr0511 49,755 Reputation points Independent Advisor
    2025-10-05T06:48:56.79+00:00
    Hello, good day and thanks for your question. May I know if this issue has started after a recent update on Edge? You can also try to logout and login again from your profile and then try to uninstall and reinstall Edge as well.
  2. Tareq Hijazi 0 Reputation points
    2025-10-05T07:21:32.5233333+00:00
    I can't really tell when it started, but I recall using this feature on my mobile a couple of months back. I will try to login and off from Edge Mobile and see if that fixes the issue. I tried both logging out and in, as well as uninstalling and reinstalling.
  3. Tareq Hijazi 0 Reputation points
    2025-10-05T11:34:44.4066667+00:00
    Same results, I tried logging in and off, reinstalling, nothing worked.
  4. Tareq Hijazi 0 Reputation points
    2025-10-05T14:27:40.59+00:00
    Tried the Dev version, same issue.
  5. Tareq Hijazi 0 Reputation points
    2025-10-07T06:07:23.8533333+00:00
    I tried with Beta and Dev versions, and I also tried on a second Android phone, same result.
