Alain, see https://learn.microsoft.com/en-us/surface/surface-support-portal
Surface Go 2 Battery not charging
We have 8 Surface Go 2 that no longer charge. They have been unused for several weeks and the batteries have discharged completely. When connected, the battery indicates that it is charging but remains at 0%. We have run a diagnostic and the battery is in good condition, capacity of 90% and more. We have reinstalled Windows without success. We want to do a bios update but this update requires a battery % of 40%. Do you have a solution to offer us? The problem is the same on all 8 tablets. Thank you
Surface | Surface Go | Power and battery
Barb Bowman 80,820 Reputation points MVP Volunteer Moderator2025-09-25T18:50:49.3066667+00:00 -
Barb Bowman 80,820 Reputation points MVP Volunteer Moderator2025-09-25T17:34:54.7533333+00:00 Alain,
Sounds like you need to open a support case with Surface for Business (assume that if you have 8 of these, you are in a business/enterprise environment.
Deleted
