how to turn on my microphone and camera
Angela Blankenship 5 Reputation points
2025-08-18T17:12:58.9033333+00:00
How do I turn on the microphone & camera and then submit a test call on my Dell laptop
Microsoft Teams | Microsoft Teams Free | Settings | Privacy
  1. Jonathan Deives 80,690 Reputation points Independent Advisor
    2025-08-18T17:50:14.7+00:00
    Most laptops have a key to toggle the camera and microphone. This key is usually located between F1 and F12 and should be pressed along with the FN key.
    To test the microphone, follow these steps:
    Select Start > Settings > System > Sound.
    Under Input, select the microphone you want to test and click "Start Test."
    For the camera;
    Click the Start menu and type Camera.
    Open the Camera app.
    7 people found this answer helpful.
  2. Ruwim.B 6,900 Reputation points Volunteer Moderator
    2025-08-18T17:52:29.77+00:00
    If what you are looking for is the microphone and camera device which is used in your Teams application, then in Teams open Settings -> Devices.
