In Access, VB, I am needing help with a IF/THEN scenario involving dates.
2025-05-27T15:00:28+00:00
I have a form that I use for task scheduling and keeping track of dates when I performed that task. It is a simple form where I have a "STATUS" field combo box with "Not Started" and "Completed" for source options. Also, in the sourced table, I have columns identified for each of the four quarters in the year. I need help with the code that, if "STATUS" is selected "Completed", and today is, for example, is in the second quarter of this year, THEN enter "TODAYS DATE" in the "Quarter2" field.
Thanks,
Jeff Bomberger
Microsoft 365 and Office | Access | For business | Other
2025-05-27T16:20:05+00:00
I think you need something like
DIM Q AS BYTE
Q = DatePart("q", Date())
If Q = 1 Then CompletedDate1 = Date()
If Q = 2 Then CompletedDate2 = Date()
If Q = 3 Then CompletedDate3 = Date()
If Q = 4 Then CompletedDate4 = Date()
11 additional answers
    2025-05-27T15:59:14+00:00
    Then show the code........
    2025-05-27T15:52:04+00:00
    I need to store multiple dates in the table is the reason for the 4 fields. I have a task that is completed every quarter, and I need to know the exact date in that quarter that I completed that task. I tried to use a "IF NULL" or "BLANK" Then Else statement, but it did not work right...
    Thanks,
    Jeff
    2025-05-27T15:30:44+00:00
    I am not very happy with the 4 fields. Once you have a date, the quarter is derived data.
    Maybe you can just store the date in a field (DateCompleted). If you want to show the quarter, use the DatePart function to calculate the quarter. There is no need to store that.
    Look HERE
