HLK and the problem "Selected machine pool does not contain any targers of this type"
Georgi Georgiev 6 Reputation points
2021-06-23T07:47:33.497+00:00
Hi MS community,
I am trying to perform a system test with HLK. I have done a straigtforward installation of HLK to test windows 2019 system.
I am using a domain setup:
Single DC
Single test server (Controller + studio) Windows HLK, version 1809
Test clients
When i install the client software on the test system i can see them in the HLK Studio in the default pool i can move them to a new pool and set them to active but then
When i click on systems and try to selet a test target for the test i get "Selected machine pool does not contain any targers of this type".
The studio and the controller software run on a single server that is a MS 2016 Server standard.
What am i doing wrong?
I have already redeployed the whole testing environment a couple of thimes and cannot get the expected results.
Windows for business | Windows Server | User experience | Other
{count} vote
    2021-06-23T08:36:30.777+00:00
    Welcome to Q&A platform.
    Windows HLK test is currently not supported in Q&A platform. You could refer to the following link to contact Windows HLK support:
    https://learn.microsoft.com/en-us/windows-hardware/test/hlk/user/windows-hlk-support
    Thank you for your understanding.
    Best Regards,
    Sunny
    If the Answer is helpful, please click "Accept Answer" and upvote it.
  2. Georgi Georgiev 6 Reputation points
    2021-06-23T09:36:16.31+00:00
    I followed the link and found out that the support forums have been moved to Microsoft Q&A
    https://social.msdn.microsoft.com/Forums/en-US/home?forum=whck
    So where to post a question ?
    2021-06-24T05:21:41.583+00:00
    Many thanks for your update.
    I consulted with our develop support engineer and he responded that Windows hardware testing currently is not supported in Q&A platform. If the issue is also related windows hardware certification, I would suggest you could post this thread in the following forum with corresponded tag "windows-hardware-certificate":
    https://learn.microsoft.com/en-us/answers/topics/windows-hardware-certification.html
    If the issue is more related to HLK, you could contact Microsoft via the following link with required information:
    https://support.serviceshub.microsoft.com/supportforbusiness/onboarding?origin=%2Fsupportforbusiness%2Fcreate
    Best Regards,
    Sunny
  4. Line H 0 Reputation points
    2025-11-10T10:16:01.2066667+00:00
    I am experiencing a similar issue. Did you ever get this resolved?Kind regards,
    Line
