How do I enable right-click Inspect Element in Edge on Android?
2024-07-15T06:41:45+00:00
Microsoft Edge | Browser extensions | MacOS
  1. Paulo GM 74,055 Reputation points Independent Advisor
    2024-07-15T09:43:17+00:00
    Hi adwissler, I am Paulo and I'd like to help.
    Unfortunately, Edge Mobile does not support this yet. However, as a workaround, you can use the Eruda project to use the inspect element and see if it works for you.
    Here's where you can access the demo:
    https://github.com/liriliri/eruda
    • In Edge Mobile, edit a bookmark and paste this script as the URL.
    javascript:(function () { var script = document.createElement('script'); script.src="https://cdn.jsdelivr.net/npm/eruda"; document.body.append(script); script.onload = function () { eruda.init(); } })();
    • Name it as DevTools
    • Open the website you want to inspect
    • Click the address bar and search for the bookmark you saved DevTools and a small plugin should appear on the lower right of the website
    Here's another instruction that might help
    https://stackoverflow.com/a/74503106
    (Disclaimer: These are non-Microsoft websites. The pages appear to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the sites before downloading and installing it.)
  2. Sumit 44,981 Reputation points Volunteer Moderator
    2024-07-15T09:23:56+00:00
    Not available for Android, sorry.
