Android Edge Browser Flickering Problem(안드로이드 엣지)
2025-04-22T13:47:48+00:00
Android Edge Browser Flickering Problem This happens when you ask to load a Naver blog page.
안드로이드 엣지 브라우저 화면 깜빡임 문제. 블로그 접속하려 하면 종종 발생하는 문제.
  • Android Version : Android 14 5.15.148-android13-8-29539737-abF946NKSS5DYBD
  • Edge Android Version : 135.0.3179.22
Youtube
Microsoft Edge | Browser crashes or stops working | MacOS
  1. paulr0511 48,205 Reputation points Independent Advisor
    2025-04-23T04:16:54+00:00
    You may want to check and test as well if this is also happening in the Beta and Dev builds that you can download and install via the Play Store and see how it goes from there as well.
    2025-04-22T18:23:56+00:00
    I'm not sure because I rarely visit other sites.
    But that happened whenever I visited the Naver blog site.
    Dark mode seems to be causing problems.
    This is the site what I've visited.
    https://m.blog.naver.com/PostView.naver?blogId=semingg&logNo=223839139253&proxyReferer=https:%2F%2Fm.naver.com%2F&trackingCode=naver_main
  3. paulr0511 48,205 Reputation points Independent Advisor
    2025-04-22T17:49:04+00:00
    Good day, thanks for your question. Just to check first, is this only happening on this specific website and there is no issue if another website has been opened in Edge for Android?
    Regards,
    Paul R.
