Launching Microsoft Edge on iOS devices
This browser is no longer supported.
Upgrade to Microsoft Edge to take advantage of the latest features, security updates, and technical support.
Hi, I am using Edge Chromium now on my myriad of computers, Macs and Windows. I have 3 simple steps I do to make it look like and feel like chrome to me. Stop autoplay using experimental settings, works fine, add the chromium newtab addin and change home page to google. Seems fine to me and its fast. Syncs stuff ok.
I am trying to configure edge mobile on my iphone. I have changed search engine to google - but the home page I cant seem to figure out how to change. I would prefer it just bring up the google home page. If I search it is google, so I can live with it, but can I not just have the google home page? And if nothing else can I get rid of shpping facebook netflix etc from the home page, I don't use any of these and I don't want to.
Thanks
Hi, WilliamDossett,
Go here to Make Google your Home Page
Launch Safari
Top Left select Safari > Preferences > General
Next to New Window Open With or New Tab Open With > Select Homepage
Next to Home page type www.google.com
Facebook, Netflix
I'm assuming you mean on the home page you see these icons
You should see an X in the upper right corner
Click on that to Remove the icon
If you're seeing these icons on your home screen of the iphone
Touch and hold > You should see an option to Remove appear
Select that to remove from home screen
Thanks, but as the title says, this is edge mobile, on my iphone. I figured out how to make it use google for search and get rid of the icons so I just have to put up with the Microsoft logo on the home page unless you know how to change the home/start page on Edge MOBILE to google.com?
Steps to change Safari home page
