Problem with Facial Recognition and PIN
2025-06-27T02:40:58+00:00
Help! I have a Microsoft surface go and my facial recognition stopped working. I can't log in and I don't know my pin and it won't allow me to reset my pin. How can I get into my computer without losing any of my files and data?
Surface | Surface Go | Safety and security
    2025-06-27T07:46:34+00:00
    Hello, Darrell Simms,
    Thank you for your feedback. I understand that you are having trouble remembering your PIN code. Please refer to the following methods:
    1. On the lock screen, hold down the Shift key and restart your computer from the bottom right corner of the screen.
    Your system will restart to a special startup options menu. From there, select “Troubleshoot” > “Advanced options” > “Command Prompt.”
    In the Command Prompt window, type and press Enter: regedit
    In the Registry Editor, select HKEY_LOCAL_MACHINE, then go to the “File” menu and select “Load Hive.”
    Locate the drive where the operating system is installed (typically C:), then navigate to Windows\System32\config.
    Select the file named SAM, then click “Open.”
    In the dialog box that appears, name this file (e.g., REM_SAM).
    Navigate to HKEY_LOCAL_MACHINE\REM_SAM\SAM\Domains\Accounts\Users\000001F4, then double-click the string named F. In the opened table, locate the number 11 (first column, eighth row; varies by Windows version; 14 for Professional Edition), click its right side, press Backspace to delete 11, then type 10 in its place.
    Close the Registry Editor by typing exit in the Command Prompt window, then restart the computer normally.
    After restarting, you can log in using the built-in administrator account.
    1. If the first method does not work, you can only try to recover using a USB image.
    Restore or reset Surface for Windows - Microsoft Support
    **Note:**Surfaceis now supported on Microsoft Q&A | Microsoft Learn.
    Starting from June 27, 2025 , new questions must be posted there. Existing discussions will remain accessible on Microsoft Answers until [June 29, 2025].
    Customers will be redirected to Q&A starting [June 30, 2025].
    https://learn.microsoft.com/answers/questions/
    Best regards,
    Lizzie-Z| Microsoft Community Support Specialist
