How to fix SSRS issues when running them on Windows 11?
Sleight, Jeannette 0 Reputation points
2025-05-02T21:27:00.1733333+00:00
SSRS reports that had been running on Windows 10 are not running on Windows 11. Kerberos authentication issues.
SQL Server Reporting Services
A SQL Server technology that supports the creation, management, and delivery of both traditional, paper-oriented reports and interactive, web-based reports.
3,042 questions
  1. Adapala Naveen Kumar 0 Reputation points
    2025-05-03T08:30:11.6466667+00:00
    Hi Sleight,
    To fix SSRS issues on Windows 11:
    1. Check SQL Server Cumulative Updates (CU).
    2. Verify disk sector size and adjust registry if needed.
    3. Update ODBC drivers.
    4. Ensure browser compatibility.
    5. Review SSRS log files for errors.
  2. Olaf Helper 46,791 Reputation points
    2025-05-05T05:17:58.0266667+00:00
    With that less on informations no one can guess anything; you have to provide more detailed informations.
