Group By and Running Total and Totals using SQL Query
Malam Malam 266 Reputation points
2025-04-15T23:06:35.75+00:00
My sql query returns the following values. How do I
  1. Group By 2. Add Running Total 3. Add Total
to get it done as shown in pictured example 1, 2 and 3 below?
I need 3 queries to get the following results:
1: put it in Group By to show as
2: Add a column to return Running Total as
3: Add a Total for each Group
Developer technologies | Transact-SQL
Accepted answer
  1. Viorel 122.6K Reputation points
    2025-04-16T02:11:50.04+00:00
    Check the query for the third problem:
    select *,
        sum(Price) over (partition by Category, Unit order by SerialNo) as RunningTotal,
        case when lead(SerialNo) over (partition by Category, Unit order by SerialNo) is null
        then cast(sum(Price) over (partition by Category, Unit) as varchar(max)) else '' end as TotalValue
    from MyTable
    order by Category, Unit, SerialNo
