Microsoft Small Basic Triangle issue
Bobo Clown 0 Reputation points
2025-02-09T12:03:08.13+00:00
So basically, I'm a beginner trying to make a game on Small Basic. It's a space themed game, and there are going to be 2 spaceships, one red and one blue. So far, I'm coding the blue one and I want the controls to be like up arrow for blue to go forwards, down arrow to go back, left arrow to rotate left, and right arrow to rotate right. For this, I used the BluePlayer = Shapes.AddTriangle command, however, when I try to rotate or move the triangle, it disappears off screen. Please help. I will leave my code below for you to try to tinker around with it. Please comment if you come to any conclusion.
Code:
' Space Fighting Game"
' Setup
GraphicsWindow.BackgroundColor = "black"
GWW = 1025
GWH = 500
GraphicsWindow.Width = GWW
GraphicsWindow.Height = GWH
' Blue Player Setup
GraphicsWindow.BrushColor = "Aqua"
BlueX1 = GWW - 25
BlueY1 = GWH / 2 - 10
BlueX2 = BlueX1
BlueY2 = GWH / 2 + 10
BlueX3 = GWW - 50
BlueY3 = GWH / 2
PlayerBlue = Shapes.AddTriangle(BlueX1, BlueY1, BlueX2, BlueY2, BlueX3, BlueY3)
GraphicsWindow.KeyDown = WhenKeyPressed
Sub WhenKeyPressed
If GraphicsWindow.LastKey = "Up" Then
GraphicsWindow.Clear()
BlueX1 = BlueX1 - 10
BlueX2 = BlueX2 - 10
BlueX3 = BlueX3 - 10
ElseIf GraphicsWindow.LastKey = "Down" Then
BlueX1 = BlueX1 + 10
BlueX2 = BlueX2 + 10
BlueX3 = BlueX3 + 10
ElseIf GraphicsWindow.LastKey = "Left" Then
Shapes.Rotate(PlayerBlue, 100)
Shapes.Move
EndIf
EndSub
Developer technologies | Small BASIC
A programming language created by Microsoft that serves a stepping stone for beginners from block-based coding languages to more complex text-based languages.
  1. LitDev 131 Reputation points
    2025-02-16T22:01:59.9+00:00
    Rotating triangles and lines in SB is tricky, the top/left is at 0,0 regatrdless of the triangle coordinates entered. Suggest you use a rectangle or image where the center of rotation is the center of the shape. Trick for triangles is to create the triangle where the desired top/left is at 0,0 and then move or rotate it, or use an extension method. For more questions or support you can head to https://litdev.uk/mybb, and a topic challenge on this https://litdev.uk/mybb/showthread.php?tid=242
