How to manage via registry these options in Edge under "Profile preferences"
Marco-4658 0 Reputation points
2024-10-30T16:02:08.8266667+00:00
Hi all,
As already search docs and others sites, we're trying to find more information about this specific settings and how to manage them via Registry, can someone help us from this situation to set all to disable and also any URLs created or modified by users deleted?
screen-profiles
Thanks in advance. Any help would be much appreciated.
M.
Microsoft Edge | Microsoft Edge development
  1. Jonathan Pereira Castillo 17,505 Reputation points Moderator
    2024-10-30T16:13:56.4166667+00:00
    Hi Marco-4658,
    I understand you're looking to manage the "Profiles / Profile preferences" settings in Microsoft Edge via the Registry. Here are the steps to disable these settings and delete user-created URLs: Disabling Profile Preferences via Registry Open Registry Editor:
    • Press Win + R, type regedit, and press Enter. Navigate to the following path: HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Edge Create or modify the following DWORD values:
    • Account-based profile switching: "AccountBasedProfileSwitchingEnabled"=dword:00000000
    • Curated sites automatically switch profiles: "AutomaticProfileSwitching"=dword:00000000
    • Intranet-based profile switching: "IntranetProfileSwitchingEnabled"=dword:00000000
    • IE Mode based profile automatic site switch: "IEModeProfileSwitchingEnabled"=dword:00000000 Deleting User-Created URLs To delete URLs created or modified by users, you can use a script to clear browser history or specific registry keys. Here’s a general approach: Open Registry Editor:
    • Press Win + R, type regedit, and press Enter. Navigate to the following path: HKEY_CURRENT_USER\Software\Microsoft\Edge\TypedURLs Delete the entries:
    • Right-click on each URL entry and select Delete. Alternatively, you can use a script to automate this process:
    PowerShell script to delete user-created URLs in Edge
    $registryPath = "HKCU:\Software\Microsoft\Edge\TypedURLs" Remove-Item -Path $registryPath -Recurse Run this script as an administrator to ensure it has the necessary permissions.
    I hope these tips help resolve the issue. If you need further assistance, I'm here to help.
    Best regards,
    Jonathan
    Your feedback is very important to us! If this response resolved your query, please click 'YES'. This helps us continuously improve the quality and relevance of our solutions.
    2024-10-31T03:35:08.67+00:00
    Hi Marco-4658,
    Currently, there're only 4 policies available to manage the Profile preferences settings. You have used 3 of them:
    GuidedSwitchEnabled --> Account based profile switching
    SwitchIntranetSitesToWorkProfile --> Switch intranet sites to a work profile
    SwitchSitesOnIEModeSiteListToWorkProfile --> Switch sites on the IE mode site list to a work profile
    AADWebSiteSSOUsingThisProfileEnabled --> Allow single sign-on for work or school sites using this profile
    For the rest of the settings, unfortunately there's been no policy yet. Please send a GPO request by sending feedback to the Dev Team (Alt+Shift+I). Thanks for your understanding.
    Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
    Best Regards,
    Shijie Li
