Hey @BayramZengin-9587,
Thank you for taking time to post this issue in Microsoft Q&A forum.
As Visual Studio Code is currently not supported in the Microsoft Q&A forums, please kindly post your question on GitHub - vscode for better help.
About the error you got, I guess it’s related to permission limitation. You mentioned that it’s your companies Laptop, did administrator/IT set some rules or limits on your machine? You can try following currently:
- Run VS Code as administrator.
- Navigate to
C:\Users\username\AppData\Local\Programs\Microsoft VS Code
, right click "Code.exe", Properties, switch to Security. Select the user account, click Edit, make sure that proper permissions have been assigned, like "Read & execute", "Full control"… click Apply and click OK button, close it then restart VS Code. - Check if any program blocks the VS from running, like antivirus, group policy.
Anyway, I strongly suggest you contact with your administrator/IT and confirm that there’s no limitation on your machine. If necessary, try to reinstall VS Code.
Thanks for your understanding, have a nice day:)
Sincerely,
Tianyu
If the answer is the right solution, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
