Azure ML prompt flow QnA model works in worskspace but the deployed endpoint does not work
Oussama Chiboub 45 Reputation points
2024-09-27T13:47:57.5466667+00:00
I have been working on a prompt flow QnA chatbot for a while now and it has been working well. Recently i redeployed my model with minor changes and the endpoint does not work anymore: below is the error that i have : "Execution failure in 'lookup': (TypeError) unsupported operand type(s) for +: 'NoneType' and 'int' azure". Keep in mind that i haven't changed anything in the "lookup" node, and i couldn't find where the + operand is being done on the flow.
The prompt flow model works well in azure ML studio but deploying somehow makes this error.
Thank you for your help ! It's kind of an urgent matter
Azure Machine Learning
An Azure machine learning service for building and deploying models.
2,981 questions
Azure AI Search
Azure AI Search
An Azure search service with built-in artificial intelligence capabilities that enrich information to help identify and explore relevant content at scale.
1,083 questions
Microsoft Deployment Toolkit
A collection of Microsoft tools and documentation for automating desktop and server deployment. Previously known as Microsoft Solution Accelerator for Business Desktop Deployment (BDD).
906 questions
  1. YutongTie-MSFT 53,211 Reputation points
    2024-09-29T09:11:38.1133333+00:00
    Hello everyone,
    Thanks for reporting this issue, product team has acknowledged this issue and working on a fix. Will update here again if the issue has any progress.
    Regards,
    Yutong
    -Please kindly accept the answer if you feel helpful to support the community, thanks a lot.
  2. Erik 15 Reputation points
    2024-09-30T10:28:44.38+00:00
    A temporary fix for me was to turn of tracing by setting an env variable:
    os.environ['PF_DISABLE_TRACING'] = 'true'
  3. Oussama Chiboub 45 Reputation points
    2024-09-30T13:25:01.3033333+00:00
    Hi everyone ! I found a fix pour this error : Apparently latest open ai versions cause a problem with prompt flow tracing, so reverting to = < 1.44.1 openai python library in the requirements file fixed the issue for me
    https://pypi.org/project/openai/#history
  4. suwit 0 Reputation points
    2024-09-30T04:46:40.9233333+00:00
    error:
    The above exception was the direct cause of the following exception:
    Traceback (most recent call last):
      File "/azureml-envs/prompt-flow/runtime/lib/python3.9/site-packages/promptflow/_core/flow_execution_context.py", line 90, in invoke_tool
        result = self._invoke_tool_inner(node, f, kwargs)
      File "/azureml-envs/prompt-flow/runtime/lib/python3.9/site-packages/promptflow/_core/flow_execution_context.py", line 206, in _invoke_tool_inner
        raise ToolExecutionError(node_name=node_name, module=module) from e
    promptflow._core._errors.ToolExecutionError: Execution failure in 'opportunities': (TypeError) unsupported operand type(s) for +: 'NoneType' and 'NoneType'
    2024-09-30 04:39:01 +0000      22 execution.flow     WARNING  Failed to calculate metrics due to exception: unsupported operand type(s) for +: 'int' and 'NoneType'.
