Help with sign-in problem
Elda 0 Reputation points
2024-09-20T15:56:47.04+00:00
When I try to connect to e specific network it says "Can't connect because sign-in requirements for your device and the network aren't compatible, please contact your IT support" . Can you please help me with that?
Windows Network
Windows Network
Windows: A family of Microsoft operating systems that run across personal computers, tablets, laptops, phones, internet of things devices, self-contained mixed reality headsets, large collaboration screens, and other devices.Network: A group of devices that communicate either wirelessly or via a physical connection.
750 questions
Windows 11
Windows 11
A Microsoft operating system designed for productivity, creativity, and ease of use.
9,581 questions
  1. Bruce (SqlWork.com) 64,826 Reputation points
    2024-09-20T16:24:33.5133333+00:00
    this generally means the network you are trying to connect with requires security software be installed on your device. if the security software is installed, then your device is not in compliance with the security requirements.
    as suggested, contact the admin of the network you are trying to connect with and get their requirements.
