SCOM Alert: Data Warehouse maintenance mode synchronization process failed to read data
Brian W 126 Reputation points
2024-06-03T11:47:46.81+00:00
I'm getting this alert in my console And I'm receiving event 31555 in my Operations Manager log every 10 minutes, and when I check my syncronization object it shows unhealthy.
failed to read data||Data Warehouse maintenance mode synchronization process
failed to read data||Alert Description| | -------- | -------- | -------- | -------- | -------- | |Data Warehouse maintenance mode synchronization process
failed to read data   Data Warehouse maintenance mode synchronization process failed to read data||Alert Description| |||| |Source:Data Warehouse Synchronization
Service Source:   [Data Warehouse Synchronization Service] Full Path Name:   Data Warehouse Synchronization Service Alert Monitor [Data Warehouse Maintenance Mode Synchronization Data Reader Recovery State] Created:   6/3/2024 6:02:15 AM||Data Warehouse maintenance mode synchronization process failed to read data from the operational database. Failed to generate data to be forwarded to the Data Warehouse. The operation will be retried. Exception 'ArgumentOutOfRangeException': Specified argument was out of the range of valid values. Parameter name: dataItems One or more workflows were affected by this. Workflow name: Microsoft.SystemCenter.DataWarehouse.Synchronization.MaintenanceMode Instance name: Data Warehouse Synchronization Service Instance ID: {CC1F5220-973B-24A2-1074-A1AC46688C19} Management group: CS-SCOM|
Log Name: Operations Manager
Source: Health Service Modules
Date: 6/3/2024 7:26:17 AM
Event ID: 31555
Task Category: Data Warehouse
Level: Error
Keywords: Classic
User: N/A
Computer: T000000SCOM0001.TAMCENTRAL.ASP
Description:
System Center Operations Manager
A family of System Center products that provide infrastructure monitoring, help ensure the predictable performance and availability of vital applications, and offer comprehensive monitoring for datacenters and cloud, both private and public.
  1. XinGuo-MSFT 22,351 Reputation points
    2024-06-05T02:02:09.46+00:00
    This error typically indicates a problem related to data synchronization between the Management Server and the Data Warehouse, particularly related to Maintenance Mode workflows. It's recommended to review the workflow and configuration, check data consistency, and ensure the health of the SCOM database.
    There are no specific documents or discussions found in internet that address this exact issue.
    If the issue persists, consider reaching out to Microsoft CSS Support for a more in-depth investigation.
