Connecting to Azure SQL Edge (local docker instance) from another network machine
Sunraj sharma 45 Reputation points
2023-09-27T00:00:40.93+00:00
Hi
I have a local instance of Azure SQL edge running (using docker on MacBook).
I am trying to connect to the server, with using pyodbc (in google colab), but i keep getting this error: Screenshot 2023-09-26 at 7.51.01 PM
I already followed this document: https://learn.microsoft.com/en-us/azure/azure-sql-edge/connect
I am fairly new to this, therefore my process of connecting is 2 lined:
  1. I run the docker container, and
  2. Then try to connect using pyodbc.
I am using IP Address and Port number from Networks (key in JSON structure) in docker
  1. Using IP address found here: Screenshot 2023-09-26 at 7.53.24 PM
  2. Using Host port number found here: Ports being used
Azure SQL Edge
Azure SQL Edge
An Azure service that provides a small-footprint, edge-optimized data engine with built-in artificial intelligence. Previously known as Azure SQL Database Edge.
  1. Deleted
