MP Control Manager detected management point is not responding to HTTP requests. The HTTP status code and text is 403, Forbidden.
Boopathi S 4,036 Reputation points
2020-10-21T10:24:50.98+00:00
Below error appears in mpcontrol.log in 4 secondary site servers and not in other SCCM secondary site servers
I checked that certificate is not expired.
Please help to solve the issue.
Microsoft Security | Intune | Configuration Manager | Other
  1. Fiona Yan-MSFT 2,316 Reputation points
    2020-10-22T10:46:26.963+00:00
    @Boopathi S
    Thank you for posting in Microsoft Q&A forum.
    Have we seen the IIS log before? This error may caused when we access WebView or WebPort.When we open the log and then search "403." to see whether we could get detalied info or not?
    Here is a helpful guide for you to refer to:
    https://learn.microsoft.com/en-us/troubleshoot/iis/http-error-403-7-forbidden-web-app
    Have a nice day!
    If the response is helpful, please click "Accept Answer" and upvote it.
  2. Ryan Steele 21 Reputation points
    2020-11-08T20:17:50.907+00:00
    I can confirm that the solution posted by @Boopathi S solved the issue for me as well. To ensure others are able to find this answer, I am posting the text of the log messages below so it will show up more readily in a web search.
    The following is found in the mpcontrol.log file on the affected site server:
    Call to HttpSendRequestSync failed for port 443 with status code 403, text: Forbidden SMS_MP_CONTROL_MANAGER 11/8/2020 11:12:47 AM 7020 (0x1B6C)
    Http test request failed, status code is 403, 'Forbidden'. SMS_MP_CONTROL_MANAGER 11/8/2020 11:12:47 AM 7020 (0x1B6C)
    The following may be found on the CcmNotificationAgent.log file on a client connecting to a Cloud Management Gateway:
    [CCMHTTP] ERROR: URL=https://CONTOSO.CLOUDAPP.NET/CCM_Proxy_ServerAuth/72057594037927940/bgb/handler.ashx?RequestType=LogIn, Port=443, Options=1248, Code=0, Text=CCM_E_BAD_HTTP_STATUS_CODE BgbAgent 2020-11-08 11:15:31 AM 7220 (0x1C34)
    [CCMHTTP] ERROR INFO: StatusCode=403 StatusText=CMGConnector_Forbidden BgbAgent 2020-11-08 11:15:31 AM 7220 (0x1C34)
    Raising event:
    instance of CCM_CcmHttp_Status
     ClientID = "GUID:8A5350F6-613D-4FF1-BC44-99B4B0C6969E";
     DateTime = "20201108191531.162000+000";
     HostName = "CONTOSO.CLOUDAPP.NET";
     HRESULT = "0x87d0027e";
     ProcessID = 18388;
     StatusCode = 403;
     ThreadID = 7220;
    Successfully queued RefreshSecuritySettingsEvent event. BgbAgent 2020-11-08 11:15:31 AM 7220 (0x1C34)
    Successfully queued event on HTTP/HTTPS failure for server 'CONTOSO.CLOUDAPP.NET'. BgbAgent 2020-11-08 11:15:31 AM 7220 (0x1C34)
    Failed to post Login with error code 87d0027e. BgbAgent 2020-11-08 11:15:31 AM 7220 (0x1C34)
    Failed to signin bgb client with error = 87d0027e. BgbAgent 2020-11-08 11:15:31 AM 7220 (0x1C34)
    This issue may be affecting you if one or more certificates are returned after running the command below on your management point:
    Get-Childitem cert:\LocalMachine\root -Recurse | Where-Object {$_.Issuer -ne $_.Subject} | Format-List
    Once you have verified these root certificates are not needed, you can remove them by running this PowerShell command:
    Get-Childitem cert:\LocalMachine\root -Recurse | Where-Object {$_.Issuer -ne $_.Subject} | Remove-Item
  3. Cris Kolkman 6 Reputation points
    2021-06-23T08:41:37.22+00:00
    I'm having the same issues as @Anonymous was having, but the issue has not been solved (yet) by this solution.
    Yesterday I changed our SCCM to HTTPS only using this manual: https://gmarculescu.com/?p=81
    The only difference is our Root CA is an offline machine and we have an online Subordinate CA issuing the certificates.
    After this the clients stopped reporting to the SCCM server and they're all showing offline.
    Software Center fails to start as well:
    Running the command below showed 3 certificates not belonging in the Root store, which led me to a wrongly configured GPO deploying Intermediate certificates to the trusted root store.
    After modifying the GPO and running below command the wrong certificates didn't show up anymore, also not after a gpupdate /force:
    Now it is about half an hour ago that I corrected this (and rebooted the SCCM server) but it doesn't seem to make any difference, in the mpcontrol.log I still see below error:
    Call to HttpSendRequestSync failed for port 443 with status code 500, text: Internal Server Error
    Could anyone shed a light on what is going wrong/where should we look for maybe more errors?
    EDIT:
    It's taking a long time but many clients are starting to report again, so this seems to be the solution after all.
    Upcoming days I will keep an eye on the environment.
  4. Andy U 6 Reputation points
    2024-07-02T12:25:32.38+00:00
    Might be a bit late to this, but I have a different solution to this problem which I haven't seen anywhere else.
    We run a completely isolated infrastructure with no direct internet connection. It's only the MEMCM, AV and VMware vCentre that can access the outside world via a protocol break proxy to download patches and updates etc.
    Recently we ran into an issue with a missing certificate from the Microsoft "master" list, referenced here -> https://learn.microsoft.com/en-gb/troubleshoot/mem/configmgr/setup-migrate-backup-recovery/connectivity-issues-digicert-global-root-g2-not-installed
    As part of of sorting this I decided to also update the full list of Trusted Roots and disallowed certificates as documented here for offline environments -> https://learn.microsoft.com/en-us/windows-server/identity/ad-cs/configure-trusted-roots-disallowed-certificates
    However this caused this very issue with the MP certificate not being validated. Seems there's a limit to the number of trusted root certs a windows server can process. This manifests itself as a SCHANNEL warning Event in the System Eventlog with an ID of 36885 and a description as follows.
    "When asking for client authentication, this server sends a list of trusted certificate authorities to the client. The client uses this list to choose a client certificate that is trusted by the server. Currently, this server trusts so many certificate authorities that the list has grown too long. This list has thus been truncated. The administrator of this machine should review the certificate authorities trusted for client authentication and remove those that do not really need to be trusted.
    The SSPI client process is SYSTEM (PID: 4)."
    We had a list of ~500 Trusted Root certs from the official Microsoft list and clearly this was enough to trip it over the limit and it has stopped trusted its own client cert.
    Having pruned the list back down to ~40 and rebooted the MEMCM server the MP component is now reporting all green.
    Hopefully this might help somebody out with a similar issue at some point.
